smoke machine for diagnostics
thistle3585
- IN
- 1979 Jeep CJ5 with '72 304 V8, MC2100carb,T150 trans, AMC20 rear diff with locker, Dana 30 front diff, Dana 20 Tr Case, Procomp Springs, Gabriel Ultra shocks.
So, I'm done trying to chase down a vacuum and/or exhaust leak so I have decided to make a smoke machine. Has anyone done this? My thinking is to seal off the top of the carb, plug all the vacuum lines then hook the smoke machine tube to the manifold port on the adapter plate. Is that okay or should I try a different spot? Also, by doing that will it flow into the headers or should I run smoke through the tailpipes in to the headers? Also, any suggestion on the proper air pressure to use?
