Soft Pedal
Soft Pedal
Tin Medic
Ft. Carson
85 CJ-7 Renegade:
Fuel Injected 4.2L I6/T5/D300
D30 with ARB Air Locker, AMC 20 w/Posi
Warn 8000 LB winch
VIAIR Onboard Air System
33x12.5x15 Goodyear MT/R's
Kenwood head Unit
Hella E-Code Lights
Have a soft pedal that goes to the floor when I step on it. I have to press it several times to get braking power. I am not losing fluid and there is no booster. It seems to be worse in stop and go traffic. Ideas?
master cylinder leaking past seals, or air in system. That's all I can think of.
I am leaning in that direction also. Found some fluid leaking down the inside of the firewall.
I have a TJ master cylinder and power booster in the shop, guess I know where its going.
fittings on the lines will probably be different
will that fit? I have a cj power booster and master.Just pulled from.my Laredo
it might have metric fittings so you might have to change your fittings out on your lines the power booster will sure feel better
