Still acting up
Cjordan
Alright guys I've got a couple other threads but now that everything is changed I thought I'd start a new one.
At first with the Carter, the engine would start fine, idle smooth, and rev fast and smooth. Until you drove it, 1st gear was fine but after that you couldn't crowd it in 2nd,3rd or 4th about 1/4 throttle is all you could give it.
Since then I've change
Plugs, wires, cap with brass contacts, and button, and also just added a MC2150.
The jeep doesn't have a tach so I'm not sure what it's idling at, although it sounds low and smooth "not idled up"
I've got the pcv hooked into the big port on the back side, and the vac advance hooked into the small port facing the valve cover.
I checked the timing and its reading 8deg doesn't matter if vac advance is hooked up or not "both ways the same" checking at idle.
When I first installed the carb and fired it up, it backfired through the carb when rev up, and it wasn't running the smoothest, let it run for a few minutes and that seemed to have cleared up.
Now this thing cranks fine, idles ok, but better when I unhook vac advance, almost sounds like a miss when vac adv is hooked up, revs fine, but still won't run right in 2nd,3rd and 4th although it does run better than when the Carter was on it.
What in the world can I be missing, or what can I do to try?
I'm no mechanic by any means, but I have turned wrenches dang near all my life. Mainly tearing apart and putting back together either swapping parts, or waiting on the real mechanic "dad, grandpa, uncle" to fix what ever, then put it back together.
Any and all help would be greatly appreciated.
Ohh I did suck on the vac adv line and block it with my tongue, and the arm stayed open.
