stock engine location
Manic Mechanic
Full Time Jeeper
Gold Supporter
Featured
32
Thurmont MD
85 CJ7 4.2L 258 .040 over, T-5 trans, dana 300, dana 30 front 3.23 and lock right locker, rear amc 20 3.23 one piece axle shafts traclock
79 CJ7 304, th400 auto borgwarner 1389?? qudratrac stock rest unknown.
89 YJ 4.2L 258, AX-15 5spd, NP231, dana 30 front, dana 35 rear with posi, gears unknown
92 YJ 4.0, AX-15 5spd, np231, dana 30 front, dana 35 rear.
ok guys and gals i need someone with a stock 6cly CJ7 to let me know how far from the fire wall your motor is. mine is about a fist width away and my fan is way to close to my radiator pics and hard measurements would be great but i can do with just some pics if you have them.
Thanks everyone
Ya I’m pretty sure your motor is supposed to be a lot closer to the firewall, it’s been awhile since I had one in mine
If you need another measurement or angle pm me...cheers
On my '86 with oem air cleaner and M.O.R.E. motor mounts, I get about and inch and a half. A critical factor is that the clutch bell crank should be perpendicular to the frame or as close to that as you can get. Otherwise there will be too much load on the outer pivot and it can break, and I have seen a few of those. Usually, as the oem motor mounts age and start to sag, the valve cover will get real close to the fire wall and upset that bell crank geometry. Tou could have an issue with the body being too far up on the frame, this can be adjusted also. A body lift can be a factor also.
Let me know if you still need help. Gonna be real busy at work for the next 3 weeks so PM me to make sure I see your request.
thank you everyone i will post some pics im not sure what is going on but i cant even get a stock fan between my radiator and pully. for the time being im putting an electric fan in until i can figure out the issue. ill post some pics as soon as i can
Here is my engine in relation to the firewall
Sent from my E6810 using Tapatalk
$35.00
  17.5%
