Straight pedal, move the darned post and 6* to redemtion
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
Some of you will say .....Finally, I'm sick of hearing about it .... Honestly I agree......
My new disk brake conversion was a trial. First a bad Master Cylinder made the up until now simple job of bleeding brakes frustration and ultimately impossible. The replacement of that piece of junk with a power assist unit made the brakes actually dangerous. Tarry99 pushed me to consider moving the pin on the brake pedal from a 5:1 ratio to 4:1 ... and I did it. While at it I straightened the pedal. The result was a pedal an inch or so closer to the floor, but as to drivability is concerned, what a wonderful change. Moving the pin had it's desired affect. So, now I have brakes and I'm happy with them. But driving was a terrible experience. And Saturday was over.
Sunday - as was suggested 6* of wedge shim was added to the front. All went well, I replaced the spring stack bolt (Lumpy prepared me for that), added the shims. And drove and drove the CJ.
We went slow, we stomped on the brakes when it was safe to do it. We went fast, then faster yet, we hit the corners slow, we hit the corners fast, we even stomped on the brakes in a corner while ...... Well I am a CJ driver so I didn't stomp on the brakes too hard. I can report, NO PROBLEMS and I'm pleased.
Thank you all for your support with out which I just might have quite. .... Thank you!
