Wiring Strange Turn Signal
WannabeFree
- Standish, Ca.
- 82 Cj8 Scrambler 4.2l,T18,D300
84 CJ7 4.2l,NP435,D300,Howell TBA
Need Help on my 84 CJ7 turn signal issue. For some strange reason when I turn on my signals on for both right and left rear lights flash but the front lights function normally . I know that most issues are do to poor grounds but I have double and triple checked all known grounds and everything checks out normal. I have recently replaced the turn signal switch and replaced both hazard and turn signal flashers. I do not have any LED lights. to recap my issue, The Head and tail lights function normal, Hazard lights function normal, Running lights front and and back function normal only my rear turn signals do not function normal as both blink at the same time right or left signal. I have checked all wiring and it all appears normal , no splices etc. So I am wondering if some how the new turn signal could be the problem even if the front lights work normal but not the rear. I have spend days chasing all wiring and such to no avail and could use some helpful suggestions.
