Wiring Strange Turn Signal
WannabeFree
Standish, Ca.
82 Cj8 Scrambler 4.2l,T18,D300
84 CJ7 4.2l,NP435,D300,Howell TBA
Need Help on my 84 CJ7 turn signal issue. For some strange reason when I turn on my signals on for both right and left rear lights flash but the front lights function normally . I know that most issues are do to poor grounds but I have double and triple checked all known grounds and everything checks out normal. I have recently replaced the turn signal switch and replaced both hazard and turn signal flashers. I do not have any LED lights. to recap my issue, The Head and tail lights function normal, Hazard lights function normal, Running lights front and and back function normal only my rear turn signals do not function normal as both blink at the same time right or left signal. I have checked all wiring and it all appears normal , no splices etc. So I am wondering if some how the new turn signal could be the problem even if the front lights work normal but not the rear. I have spend days chasing all wiring and such to no avail and could use some helpful suggestions.
For both left and right rear to blink together, two possible issues: (1) there may be a connection or short between the two. Has someone wired in a trailer plug where they may have connected it wrong? Otherwise, another wiring issue to trace out. (2) Bad ground, forcing the current to "backflow" through the other light. This would be evident by seeing if the lights blink but are not full brightness. Think of it this way: if the ground on one side is not making properly, the juice will still look for a way to reach a ground source. That ground source would be back through the blinker switch and through the bulb in the other light on the opposite side. So now each bulb would see half the full voltage (two bulbs in series at that point) and cause them to both light, but at half brightness.
So if half bright, grounding issue. If full brightness, wiring allowing both sides to be connected together somewhere.
Your diagnosis is much the same as mine. It is difficult to determine if the light in the rear are half bright or not which would validate the grounding as the issue. However if I pull out the bulb in either tail light it does not eliminate one or the other from still blinking. My gut still says its some how a grounding issue and not a wiring issue but nothing makes sense when all other lights function properly. Is there some Ground under the dash or to the turn signal switch I am possibly not seeing or over looking. I also now am seeing a rapid flasher on both the hazards and the turn signals that just appeared while troubleshooting. I also do not understand how the back turn signals appear bonded but the front operate properly.
Thanks for all the suggestions and any new ideas., Dave
OK, I think I will try de-pinning the turn signal switch wires one at a time that control the turn signals. Is there a trick to getting them out other than using a small pick or screw driver to try and release them. I have never done it so I don't want to damage the connector. This is a new switch I just installed but my 84 CJ7 wiring is slightly non standard as the turn signal flasher unit is not in the fuse block but instead hangs in a separate plug near the emergency brake. this confused me at first but I read that some CJ's in that year were wired that way. I am wondering if maybe the turn signal switch pin outs night be slightly differently for the turn signals and hazard light circuits ?. I doubt that is the problem but if I pull the pins and try using some temporary jumpers it might resolve that. I am also going to double check which filaments in the rear tail lights are actually flashing for the hazards and the turn signals which should give me some insight as to whether its still a ground/ back feed issue or not. I do not think it is a rear light grounding problem because I have checked it and I already added hard grounds to the front running light housings. I have not checked the marker lights ground because they seem to work fine but I will check them too.
I really appreciate the help and am determined to get it resolved . Hopefully this will help some others who might have similar issues in the future.
Thanks, Dave
I use a small pin (like for fabric) from my wife's sewing room to press the small "clip" and release the connector pins.
I think I have figured out the Problem. when I ordered the new Turn signal switch there are two nearly identical parts from Standard Electrical. The model numbers are tw20t & tw20 the only difference is the 20t part# is for vehicles with cornering lights which am to sure what they are but my 84 CJ7 does not have them. The physical switches themself are identical but the one wiring is slightly different. I only noticed this when reviewing my order from Amazon Online it says not compatible with my 84 cj7 and points me to the tw20 model. So I ordered the replacement and will change it out and hope that is the end of this problem. I will check back in a few days after I get them swapped out.
Thanks again for all the help and at least I resolve or prevented some issues regarding grounds going forward. Dave
Problem Solved:
I replaced the turn signal switch with the proper one and everything works as it should now. Lesson learned , double check your parts for compatibility and don't assume just because its physically the same that the wiring is correct. In my case it was not so easy to determine because some online parts suppliers listed it incorrectly.
The good news is I have inspected and corrected other wiring issues and I fixed a lot of ground issues. All my wiring harnesses got cleaned up and properly secured in the process.
Just a heads up Rusty Iron Junkies…..
I’m VERY Old Sokol !
YES, I will still complain about Parts Counter people
Asking “What Year and Model sir” when you ALREADY
Have Done the “Home Work” for them…..ALL I WANT is
a 1157 light bulb !!
But now days, interning a VIN Number on parts orders
Is a “Wrench Throwing, Anger Management” stopping first help.
So, take a picture of the MFG/VIN Sticker in your door jam, keep it
In your phone to show to your Parts Counter Person.
Don’t feel like you did something wrong.
I still get the wrong parts even with following the Above.
Glad you got it solved.
Be looking for a “Turn Signal Switch for Sale”
With “RARE side Lights Option” on the site.
Nice rust free one like mine ! :chug:
The picture is after I recently did a lot of rust repairs including a new driver side floor pan replacement. I recently repainted it in my garage with Summit White single stage paint. It looks good from 10ft but has a little orange peel . I will will cut and buff it soon to make it look even better. I have owned this Jeep for more than 30 years.
A forty plus CJ paint job from ten feet is a FANTASTIC paint job!
Don't sell your self Short!
IT'S A JEEP !!
Unless you want a Maul Crawler......LOL
Take it down a Forestry Road, and Call it Done.
It looks like a JEEP.
Put your best In the Woods Clothes on.....
And Treat it like one.
It looks perfect
Electrical Relays
$45.00
  22.5%
