Stuck on the side of the road
TroyaCantrell
Old Time Jeeper
- Media
- 9
- Orangevale, CA
- 1966 CJ 6, Buick V6 Dauntless,
Dana 44 rear, Dana 27 front
Trans GM SM 420
First Gear ....... 7.05
Second Gear ... 3.57
Third Gear ...... 1.70
Fourth Gear ... Direct
Dana T-case (twin stick)
1970 Glass dune buggy. Short pan 1600
2008 Chevy HHR SS
So as an update to my earlier post the CJ did not make it home. Currently stuck waiting for the wife to come with a tow rig.
It seems to be starving for fuel. It filters are good, there is pressure is the line all the way to the carb. It's a Rochester 2 jet. Pulled the top off and bowl was dry , assuming float is sticking.
If it sits it will start and run for bit, a load sea to be a problem and sometimes even just parked applying the throttle will cause it to stall.
Any other ideas to try while waiting for my tow??
Troy Cantrell
Build thread - '66 CJ6 :
http://www.jeep-cj.com/forums/showthread.php?t=15075
Troy Cantrell
. There is carb cleaner in the fuel now and it could have just clogged up the jets or is sitting in the bottom of the bowl.
