support mount for dana 20?
ttbiker
Springville, UT
'76 CJ7
Alright, I am almost ready to start driving my CJ7 with the Chevy LT1 engine and TH350.
My question is do I need an additional support for the Transfer Case ? I am using the mounting pedestal built into the Transmission , but want to make sure it would be strong enough.
Any suggestions?
What adapter did you use for the TC? Did it have a provision for a mount? If so I would use that one. It would help distribute the weight. If not and the Tcase is close to the Transmission , it should be fine. You might consider making a torque plate if needed.
You have a very unique setup going in your Jeep CJ. You didn't mention what Transfer Case you are using. I know that the Dana 300 will bolt up to the TH350 and with an adapter there are others. Transfer cases are usually very heavy. Most use a skid plate for the mount with a regular Transmission type rubber or poly mount. Some will have a torque mount with the automatic transmissions. Most of these mounts are located between the transmission and the transfer case. Not knowing your complete setup, it's hard to say where the mount will go and what are you attaching it to.
TCase Dana 20
