swapping ring/pinion
grnmtn
north alabama
85 CJ7 258 I6, auto, dana 300
I found a set of axles out of a '77 QuadraTrac CJ7 w/3.54 gears. I am looking to replace my 2.73 gears in my '85 and want to know if there would be any problem in swapping out the diff/gears from these axles to mine.
I found a set of axles out of a '77 quadratrac CJ7 w/3.54 gears. I am looking to replace my 2.73 gears in my '85 and want to know if there would be any problem in swapping out the diff/gears from these axles to mine.
To answer your question, if both sets are stock, not a problem.
Are you running stock tires?
If not, the difference in gear ratio may not justify the roughly $200 in set-up costs.
If I were running 33" I'd go with 4:10s-4:56
:agree: 4:10's or so would be alot better.
Hello, I have a 1980 CJ7 that I put dich wich tires on 33", I keep breaking back right axle. I pulled the covers off the front axle and back axle and found that the front ring gear has 46 theet and the pinion has 13. (3.54) The back ring has 39 and the pinion has 11 (3.55), would this be the reason? any info would help.
No, it would have nothing to do with breaking your axle shaft.
I would recommend starting a new thread in the tech forum
Hello, I have a 1980 cj7 that I put dich wich tires on 33", I keep breaking back right axle. I pulled the covers off the front axle and back axle and found that the front ring gear has 46 theet and the pinion has 13. (3.54) The back ring has 39 and the pinion has 11 (3.55), would this be the reason? any info would help.
No that is close enough to not matter.
What rear do you have? If it's the AMC20 do you have the stock axles or the 1 piece axles? Also where is it breaking at?
You should start your own thread.
$45.00
  22.5%
