T-18 to 401 help needed
Maryland
'81 CJ-8 Scrambler
I'm in a tough spot and i need some help. I recently gathered up all the parts and pieces needed (so i thought) to swap a ford T-18 into my Scrambler, but went i went to bolt the bellhousing to the engine i found that i don't have enough clearance inside the bell to accomodate the clutch and throwout bearing stack. I am using an Advanced Adapters bellhousing part# 712569 which mates perfectly to the block but only allows 6-1/8" of clearance inside of the Bell. does anybody know if the T-176 bell offers anymore clearance?
here's my total stack:
Flywheel - 1-1/2"
clutch Disk - 3/8"
pressure Plate - 2-3/4"
throwout bearing - 1-9/16"
anybody have any advice? or ran into a similar issue.
My second question is:
Will i need to cut the floor pan to accomodate the the Transfer Case shifter when using a Dana 20 ? it sure does look like it when test fitted.
__________________
I remember hearing that the T-18 will mate up to all V8 up to the 390 but the 401 had something different.
The AMC bell housing to block bolt pattern is the same on both the I6 & V8 from 1972 on except the top center bolt on the 401 may not be drilled and tapped. I assume you have the 401 in place and that the driver’s side motor mount was not moved to go from the I6 to the V8. I don’t know what you have for a bell housing but I would try to find a stock 1976 to 1979 CJ housing (or one that has/had a T150 behind it) as it will be drilled for both the CJ T18 and the Ford T18 and will be the right depth for the input shaft. (Still need the special pilot bushing for the Ford.) The Ford T18 and the T150 both have the Ford “butterfly” transmission bolt pattern.
PS: The FSJ bell housing to transmission is different.
I would agree. I have a 401 with a Ford T-18 mated to it. I am using the original bell housing that had a T-150 behind it when I got it. Used advance adapter parts and everything fits fine.
Jeep CJ T18 is unique.... Identification and some facts
The FORD T-18 is your issue. The ford t18 has a longers input shaft and the CJ T18 has short input shaft. The CJ shaft is very short and is why the CJ T18 is worth more money. The front input shaft can be changed to the short CJ but its pricey. I think the input shaft and rev and 1st need to be changed if I remember right. Novac will have the parts. I would also consider getting the correct T18
The adapter from the T18 to Transfer Case the Dana 20 and the Dana 300 is also another expensive piece if you do not have it already. I think these are close to $400 if you do not have them.
I have a T18 with Dana 20 combo if interested. I purchased for a spare for my T18. But the granny gear is not the same I have the 6 : 1 and the spare is 4 : 1 ......... so I am going to sell mine if you need one. Came out a CJ5 because they needed auto Transmission due to injury. I have cleaned it up and appears to be all there. Needs a shifter for trans ($50 new at novac) and needs the vert shaft and knob for the Dana 20. The long horizontal shaft (unique to CJ) are there and complete. The unit is clean in and out asking $800 if you are intersted.
The input shaft for the CJ T18 is, shortest of all the T18s and is 7.43" long.
Here are some other T18 Jeep notes:
Jeep T18 Identify Facts & Model Descriptions
Jeep T18 IDENTIFICAION:
1….Has Rectangle, Flat Side Top cover mount casing
2….Texas mount pattern to the bell housing, narrow on drivers side.
3….CJ version has 7.43” stick out from the transmission wall, shortest of all versions made
Granny Gears 17 & 23 teeth, the first input gear, 17 teeth is 6.32 and 23 teeth is 4.03
Confirmed the T18 1b used in jeep, novak thought it was all narrow but mine is Wide Ratio Per Yr???
Top Mount Cover…. Jeep is Sq and the Ford and IH both have a bump on one side
Parts Via Novak
New straight shifter… $54 via novak and the tip end has lots of the play, so good to get new.
Parts are avail for T18 even the granny gears and the input gears are the trickest to do since there are many combos. Novak has the both granny gears.
Re: Jeep CJ T18 is unique.... Identification and some facts
The FORD T18 is your issue. The ford t18 has a longers input shaft and the CJ T18 has short input shaft. The CJ shaft is very short and is why the CJ T18 is worth more money. The front input shaft can be changed to the short CJ but its pricey. I think the input shaft and rev and 1st need to be changed if I remember right. Novac will have the parts. I would also consider getting the correct T18
The Ford T18 transmissions generally used for replacement in a CJ behind an AMC I6 or V8 have a SHORTER, not longer input shaft than the CJ T18 version, hence the need for the special pilot bushing. The bushing makes up for the shorter Ford shaft. Per Novak the input shaft on the Ford T18 has a stick out of 6-1/2” while the CJ T18 is 7.43”.
As far as value the CJ T18 is a more rare bird than the Ford T18. The CJ T18 was only offered as a factory option from 1972 to 1979 behind the I6 except in 1979 when the T18 could also be ordered behind the V8, and the coveted 6.32 first gear version was only available starting sometime in 1976 thru 1979. I don’t know the number of CJ units originally sold but it has to be a much reduced number compared to the Ford T18 as the Ford built a ton of pickups with the T18 over the years. Add to that the fact that the Ford T18 is going to require some adaptors that the CJ versions will not, which of course cost money, the value of the Ford T18 is further reduced from the CJ version. Two adaptors are required to bolt a Ford T18 into a CJ, the special pilot bushing referenced above and a rear shaft/adaptor plate kit as the Ford versions are set up for 2 wheel drive. The rear adaptor plate on the CJ version is in fact a part of the CJ transmission and will bolt up to the large hole Spicer 18, Dana 20, and the 1980 Scout Dana 300 that came behind the T18/19.
All of this assumes you have the right bell house. The 1976 thru 1979 CJ bell housing will be drilled and tapped for both the Ford and the CJ T18s.
$35.00
  17.5%
