T150 kicks out of 1st gear
mechjono
kaplan louisiana
1978, cj5, 304 V8, T-150 transmission, Dana 20 T case , all driveline stock, currently a project that is not running.
Hello
Rebuilt my Transmission and now it wont stay in first gear. Put new bearings,seals, new input shaft, new main shaft, new blocking rings and plates for the synchros.
Seems as though the blocking ring for ist has too much play between the syncro gear and the low gear, it allows the plates to slide back and the shifter gear never climbs over the plates.
Has anyone run across this before?:confused:
Sounds like a shift fork issue . . . .
Mine kicks out once in a while but mine is old and was told it is the synchros. Not a Transmission man by any means. Will be interesting to find out what you find. Nothing more frustrating than doing re-work!
