T150 Shift lever seal?
fuzzy
Maryville, Tennessee
79 CJ5
Is there some kind of seal or boot that goes between the concave washer and the part that screws down holding the shifter lever in? Not talking about the one that mounts to the floor, this one would go inside the Transmission . Looked at a breakdown at Morris 4X4 but they dont show the shifter. Any help is appreciated
I do not believe so. are you passing oil from the top?:cool:
QUOTE=fuzzy;129553]Is there some kind of seal or boot that goes between the concave washer and the part that screws down holding the shifter lever in? Not talking about the one that mounts to the floor, this one would go inside the Transmission . Looked at a breakdown at Morris 4X4 but they dont show the shifter. Any help is appreciated[/QUOTE]
Mine didn’t have a seal on it. Make sure you goop the bolts on the top cover as if you don’t leaking at the bolts is common.
$45.00
  22.5%
