T176 questions
jccj
Hi guys and gals,
I have a couple of questions about a T176 I have just purchased to swap out my T4.
First, can anyone tell me if the reverse switch from the T4 would work on the T176?
Also the PO had this bolted to a Ford block and had to cut about 1/2 off of the end of the input shaft, do you think it will still reach the pilot bearing on a 4.2? I did get the T176 bellhousing but comparing the T176 sitting in the bellhousing to the T4 in its bellhousing the end of T176 is flush whereas the T4 sticks passed the end of the bellhousing about a 1/2 inch.
Any help would be greatly appreciated.
Thanks,
Jon
Thanks,
Jon
