T177 and Skid Plate Alignment
Neuner
Old Time Jeeper
Went from a T-5 to T177. I am having slight mounting misalignment. If I mount the plate, the tranny mount is off by about 1/4 of an inch Northwest of where it needs to be.
Also, the front driveshaft slightly rubs against the plate whereas there use to be about a 1/4" clearance before. If I didn't have a CV joint, it would be much worse.
I've tried forcing both the plate and/or tranny around to get them to align with no luck. I really don't want to butcher the plate if I don't have to. I would like to find the cause first.
I attached photos of the holes I'm using and also how even the tranny stabilizer bolt is at an angle in an attempt to align.
I've tried several different variations of the mounting holes on the plate, frame and tranny and this is the closest I've gotten. What in the hell could be wrong?
