T5 trans fluid what to get.
Shaunman1979
Syracuse, Utah
Okay this is probably a no brainer for everone but the last T-5 I played with was in a mustang and I was running DextronIII and this Transmission was deff a gear oil I dumped out.
Okay so my question in the Haynes manual I have it has proper gear oil weight listed for all the trannys but for the T5 it says to use "jeep Transmission Fluid" So what weight is going to be sufficient for the jeep T5? Thanks in advance for all of your help.
Side question, Do you find it easier to install trans and Tcase as a whole unit or install them seperatly? (t5/Dana 300 )
The T-5 uses automatic Transmission fluid. Dexron is fine.
As for replacing the tranny and T case. I do them one at a time. It's easier and lighter that way.
I had a 1982 CJ7 with a 65 lb. T5 transmission and replaced it with a 165 lb T-18 . The last thing wanted was another 80 lbs hanging off the back of the tranny while trying to line it up.
I'll see if I can find the article, but AT fluid isnt the fluid of choice anymore. It was quickly discovered that AT fluid didnt work well in the T-5
