Had two minor fails today - just par for the course around here LOL. In preparation for a potential startup this week, after getting the wiring buttoned up I started adding all fluids yesterday - got the transmission and transfer case juiced up, and everything was going well. Today after the daughter unit headed home, I went back out to the garage, and started adding fluid to the differentials....... rear went without a hitch. Moved to the front. Tie rod and drag link were in the way of the gear oil bottle. No sweat - I'll just make a funnel out of another jug....... cut this part out...
Stick the handle in the fill hole.....
Nice gaping hole - can't miss that.....
Apply copious amounts of squeeze, and immediately overfill the funnel, and run gear oil out all over the punkin, floor, my hand, etc. (If you've ever wondered just how slow 90wt will flow thru a "tube" that small, ya better pack a lunch when you try it....) Got that cleaned up, and improvised a new filler tube..... Ahhh, much better....
Moved back under the middle of the Jeep.... oh, look - fluid dripping off the drain plug on the tranny...... Well, no kiddin, it's only finger tight. Snugged that up, looks fixed. Ate dinner, and - oh, look - more dripping from the drain plug. Made another nice funnel out of a 2 liter bottle, and got set up to drain fluid out of tranny into the jug..........
loosen plug, hoist funnel / jug to just below plug, twist about 3/4 turn, and drop the d@mn plug down into the jug.......
cover the hole with left thumb, grab jug with right hand, start to turn jug over to retrieve the plug, and inadvertently move left thumb, running gear oil into my armpit. Startled by a now well lubed pit, pour what little gear oil was in the jug about 6" left of the pan ( plug stayed in the jug)........ in reapplying left thump to drain hole, slam head into skid plate. At this point, I just said screw it and drained rest of the fluid on top of the drain plug......
After a hand cleaner sink bath, got that all sorted out.....
On a bright note - got my brake line stay 3D printed at work Friday - I believe it's gonna work well.......
Still hoping to fire the beast up tomorrow.....
