Build Thread The '80 FrankenJeep frame off reassembly
I wanted to hit a couple overlooks on the Parkway this past weekend and catch the leaves...... couldn’t make it work. May try tomorrow
Nice!! :chug:
Arm rests will be a great addition to your half doors
Interested to see what you envision for them. I just rest my arm on the big flat section of the top. Never had an issue. But I might realize I have always had an issue once I see what you come up with.
interested to see what you envision for them. I just rest my arm on the big flat section of the top. Never had an issue. But i might realize i have always had an issue once i see what you come up with.
x2 ^^^
Did you have any problems with your lug nugs on your front axle being to short for your wheels? I have the same looking wheels when installed only had like 3 to 4 threads. I did find some studs that are 3/8 inch longer now i have around 1/2 inch or so of stud sticking out.
The top of the door works well, I’d just like it a bit higher. LOL - When I get em done you may realize you truly never did have a problem... [emoji16]
No, my lug nugs worked very well. I had to order new ones cause the old ones were beat up and rusty. The shank on em is about an inch long, which was about the same as the thickness of the rim at that point. I did use the original studs....
Looks like we have the same crappy weather
Yup - Calling for sleet here Thurs morning
So you have to be revving to get full sweep? Does it increase gradually with revs or go from short to full all of a sudden?
Either way, it seems voltage related. Do you have a bad ground somewhere?
And yeah, the weather is so stinking wet and not looking forward to the “wintry mix” on Thursday. Ugh.
Actually, none of the above. I was getting partial sweet - like 80%. When I hit wide open, it must have unjammed something. Now I get full sweep like I should in all gears, I mean speeds. Kinda strange. Doesn’t sound any different, but works as it should now.
Don’t worry, be happy.....
Sorry - I had to
That’s a pretty interesting idea converting to hiem joints, it will be interesting to see when you get done
I’m mulling it over in my head - I think I’ll start gathering parts for a proof of concept prototype.
Something so right about a Christmas wreath on the grille of a CJ
