Build Thread The '80 FrankenJeep frame off reassembly
Wow! That is a lot of RVT - I sent you a PM.
Yep - first time installing an intake.... ain't the purtiest thing I've ever seen..... LOL
Just to wig out the paranoid, I sent this from my drone.....
it sure looks like all that sealant was holding tho
If it makes you feel any better, I just broke $112 of rare left hand thread bolts off inside my differential because I didn't realize they were left hand thread.
Oh, man - may not necessarily make me feel better, but does make me feel included [emoji6][emoji106][emoji106]
Well, it’s a good news / bad news day. Good news - intake went back in without a hiccup. Better than I expected.
Bad news - just to confirm the intake gasket was the issue, I reconnected all the hoses, and started filling the radiator with water. About a gallon and a half in it started running back out of the oil pan. Sooooo, doesn’t look like the intake gasket was the issue. I made no noise like a thrown rod, and everything in the top of the block looked good.
I can’t decide whether to drop the oil pan or pull the timing belt cover first
Man that really sucks I wonder if you have a problem with one of the head gaskets.
Compression check is next..... at this point I hope so. Anything else is gonna be BAAAAAD
😤 That really does suck !
Poop man that’s really suckin hope it goes well
Had to move the daughter unit to Charlotte, NC today - packed the truck yesterday and drove down this morning. Over the last couple days, I had two very knowledgeable folks tell me I blew a head gasket (and I have a related joke later...). I just never could wrap me head around how a bit over a gallon of water could get all the way up to the head from the lower radiator hose.
But it did.
Compression showed two cylinders at 155 psi, three at AMC 150 , two at 147, and one at 0.
So now I have a plan........ New head gaskets. Now, by a show of hands, how many think I was a total idiot for not doing the head gaskets when I had the engine out and on a stand?? I’ll go first [emoji113]
Well - better the head gasket than a pushrod stuck they a water jacket. Or a big ol crack in the timing chain cover.
Nuthin worse than a big ol crack......
Older fellow and his wife were e traveling through the upper New England area when the car began to run terribly. As luck would have it, they had just passed. A service station so he turned around and pulled in. After explaining the symptoms, the mechanic told his to take his wife across the street and let her browse some of the local stores and come back in a couple hours. While the wife was in the jewelry store, he wandered over to the drug store, had an ice cream cone, then went to check on any progress. As he walked in the service bay, the mechanics looked up, said “Hey, looks like you blew a seal!”. Old guys wipes his mouth and says “nah - just had ice cream”
LMAO. Bet it was one of those NCal Seals
It's good to see you are keeping a sense of humor.
$150.00
  75.0%
