Build Thread $600 CJ5!
I hope they aren't wrong! I did a YJ spring conversion and those are the new shackle hangers from Rocky Road with Old Man Emu springs.
Looking at photos on the RRO website and everything looks okay. I imagine when I get 1000lbs of engine and drivetrain in there it will look a little closer to normal.
The shackles might swing forward under more weight of the motor and body. Maybe they’ll make it far enough.
I’ve had issues with front YJ springs being too short, once the new shackle hanger is installed a bit forward from stock CJ position.
Sometimes manufacturers just make em too short (Rubicon Express did).
You can check by measuring your old springs, from the center bolt to the eye, along the edge of the main leaf. Then, compare this to your new ones. New ones should be about 1-1/2 - 2” longer.
