The UPS man came to my door today,
Sorry didn't take my viagra today....:p
Hell, a tick shouldn't be anything much. Prolly the good ol AMC valve tappet rattle ferry coming to visit.:D Try runnin a can of marvel through the oil to see if it wont clean it out a bit. Mines been rattlin for years now. How did the plugs look when you pulled them? The rough idle could be a roasted plug, a bad wire connection from someone making crappy wires :p
Oh man Its on now, you know how sensitive he is. :popcorn:
:laugh:
The rough idle could be a bad wire connection from someone making crappy wires :p
O WOW! CW you just opened a can of worms there!:D
EB what was the cost on this? Might try this once you ran it for a while.
:confused: Was it something I said???
:D
:laugh: You guys are hilarious...
Anyway, I just came back in, one of the shops here has a mechanics stethoscope, we got in and listened to all of the cylinders, the ticking is definately coming from #1 cylinder. I think I've got a bottle of Marvel in the garage, I'll figure on changing the oil this week and dumping that in there, maybe that'll loosen things up. If not, I haven't done a valve job in forever... that may end up being my next project.
Ignition box, coil, plugs, plug wires, adapter to fit the Ford duraspark, cap, rotor, and remanufactured distributor totalled right around $400.
It doesn't matter though, you want to spend that money on my Tuffy console, not an ignition system upgrade... :D
Yes I do want that tuffy box. This will be in the future after the reviews that you give. I would say in about a year after you work out all the bugs on the EW upgrade.:notworthy::notworthy:
SHOTS FIRED!!:eek::D
A year :confused: Shoot, that's not giving me an aweful lot of time, you better figure on at least two years :D
elwood i have the same ruff idle problem as you. first i thought it was the pos carter bbd. but when i put the motorcraft on it was still there. i have messed with the timing but no help. had it since i got it. i was hoping switching to the gm 4 pin module would help but it didnt.
Thanks dalefan, that makes me feel a little better :chug:
That the noise that I thought was an exhaust leak but finally figured out isnt, it's definately a sticky valve spring. Weather it's sticking, loose, tight, or getting ready to break, I don't know yet. I'm hoping that the bottle of Marvel Mystery Oil will help it out. I also discovered that my passenger side motor mount is going bad and I'll probably need to replace the motor mounts soon, that has a lot to do with my engine shake.
i tried mystery oil and zmax in mine and still have the noise. this is probally what is causing our ruff idle.
Try the fuel additive trick in that fuel additive thread I posted.
It'll clean and lube the valves.
Went for a ride today and got her good and warmed up. Brought her back to the garage and had a good listen inside the engine, stuck a really long screwdriver down into the oil fill opening and pressed it against the valve cover, and had a listen that way.
I think I'm beyond a sticky valve that needs lubricated. I'm thinking winter project may end up being a valve job.
