things I learned about Spartan lockers today
IOPort51
- Featured
- 5
- Garland Texas
- 1977 cj-5
2006 Toyota Tacoma
I decided to pull the pin on the front axle drop in locker project today. I had heard that the install was a half day job so I planned on 8 hours.
As the first point , this is in no way a bad report on the locker. The install will require a bit more time and energy than I had planned but so far I think this is still a good option for a d -30 front axle.
On page two of the install pamphlet it says "if you are running a low ratio R&P, such as a 4.88 or 5.13 you may find your ring gear is too thick to allow removal of the cross pin shaft."
On the Dana 30 I would have to say that if you had a 2.73 you may be able to get the pin out with out removing the ring gear.
So, this means that the axles have to come out and the carrier removed to allow the ring gear to be removed to get the spider gears out.
The big question is whether or not I can put the carrier back in with the proper pre-load with out a Dana axle spreader. I had just about decided to have a gear shop assemble the Dana 44 for the rear as they would charge me about as much for labor as the spreader will cost. But now I have two axles I will need it for, so the plan could change.
Has any one re assembled a 30 with original shims and considdered the job successful??
If this becomes much more involved I may regret not going with a stronger locking carrier.
so much for the easy way.
