timing question
timing question
shawn sto
clackamas Oregon
1976 cj5 with LS 1 turbo 350 dana 300 1 ton axles with disc breaks,,,,1979 cj7 hardtop with inline 6 ,3 speed and not sure transfer case and pretty sure stock axels.
does anyone know what the timing on a 1979 inline 6, 2 barrel weber carb with a comp cam, should be??
Initial advance should be 4-8 deg advanced.... with a target of 6. Go too far and will not start well and could rattle too...
Here is a very good write up on the WEBER/Jeep Combo. Read the links and will show you lots of tricks to make you Weber and ignition run better.
here is the weber/jeep tune link
www.jeepforum.com/forum/f8/weber-34-dgec-carb-too-rich-jets-tune-jeep-4-2-258-a-631105
Having a non stock cam will also affect your set up and time curve...
Weber Carb in Jeep Cj 258 / 4.2
your are welcome....
Let us know how your work goes.
Would like to see some pics, top and side so engine, esp the distributor area
Pretty good with the webers... I wrote the article you were sent to..
good luck
whatcha find out...just did a rebuild and put in a comp cam....seems for a good idle i had to set mine near16ish at idle for a good idle? thought maybe cause of the cam...was gonna contact comp
once you change cams your kinda on your own with timing depending on how big a cam you go with. Chances are you will end up with more than stock though. Just be sure you don't get any pinging under load.
    Best for votes
    on specific items
