timing question
timing question
shawn sto
clackamas Oregon
1976 cj5 with LS 1 turbo 350 dana 300 1 ton axles with disc breaks,,,,1979 cj7 hardtop with inline 6 ,3 speed and not sure transfer case and pretty sure stock axels.
does anyone know what the timing on a 1979 inline 6, 2 barrel weber carb with a comp cam, should be??
Initial advance should be 4-8 deg advanced.... with a target of 6. Go too far and will not start well and could rattle too...
Here is a very good write up on the WEBER/Jeep Combo. Read the links and will show you lots of tricks to make you Weber and ignition run better.
here is the weber/jeep tune link
www.jeepforum.com/forum/f8/weber-34-dgec-carb-too-rich-jets-tune-jeep-4-2-258-a-631105
Having a non stock cam will also affect your set up and time curve...
Weber Carb in Jeep Cj AMC 258 i6 / 4.2l / AMC 258 i6 / 4.2l
your are welcome....
Let us know how your work goes.
Would like to see some pics, top and side so engine, esp the distributor area
Pretty good with the webers... I wrote the article you were sent to..
good luck
whatcha find out...just did a rebuild and put in a comp cam....seems for a good idle i had to set mine near16ish at idle for a good idle? thought maybe cause of the cam...was gonna contact comp
once you change cams your kinda on your own with timing depending on how big a cam you go with. Chances are you will end up with more than stock though. Just be sure you don't get any pinging under load.
