Timing Question
sgtshortt
- Rolling Prairie, Indiana
- 1986 CJ 7 2.5 L 150 ci 4 speed 1 bbl ohv gas soft top, hard top, Nutted
2006 Commander 4.7L
So I bought this 1986 CJ7 2.5L. It had a small engine fire. I rewired it and it still wouldn't start. Did a Nutter Bypass and fired right up. I then discovered the reason for the fire was the serious oil blowby. I pulled the motor , tore it down and found that #2,#3 cyclinders / pistons had broken rings. I replaced all rings, bearings, block honed, valves hand lapped. Put it all back together .
I got the motor put back in and can't get it started. I have gasblowing out of the top of the carb. All spark plugs are firing and the distributor is on with pistons.
Could the cam be off by a half turn or so from crank ?
