Titled transmission
Titled transmission
somedude922
Mckinney, TX
1979 CJ-7 Golden Eagle AMC 360, TH400, Quadratrac, AMC 20 and Dana 30 narrowtracs.
Might want to check the bolts that hold the Transmission to the engine too.
There is really only one way to attach the bell housing. That is if the indexing pins are still in place. Not likely missing though, you'd be having trouble with your starter binding. There's the other end the Transmission bolts/holes could be off a little.
Does the jeep run well with no signs of troule? If so it isn't likely that your going to have any trouble with a slightly canted, it's mostly a cosmetic concern.
No problems at all. It actually runs perfect. All mounts are MORE mounts and in great condition. I've just never noticed it before. I guess you find new things when looking at your jeep from new angles. I guess I want sweat it. Thanks y'all!!
Don't fix what ain't broke.
That's a deep aftermarket pan I bet.
It is a deep pan. Extra qt of fluid in there. I have a Transmission cooler as well. Just never noticed it before! Now on to my leaking AGE box!
AGR box I mean.
$45.00
  22.5%
