Took axles out to chage seals.Advice on what next
ftwflh
Crossville,IL
1976 CJ 5, 232 6cyl 3spd lots of rust,good frame,Dana 44s w/373 gears,ProComp 4in lift kit
You might see if there's a speedy sleve to fit it. CJ posted a link to their site in the threads speedy sleve for Dana 300 yoke. Or you might find some used stock axles cheap. Another option would be to up-grade to some stronger aftermarket axles with the bigger u-joint.
If the spindle bearing fell out I would be worried the spindle was wore and needed replaced, it should be a light press.
The spindle bearings didnt fall out of the spindle.The needle bearings fell out of the bearing.
I found a stock replacement axle on Ebay for $115 shipped.I would be wary of a used one off the net.May be as bad as what I have.Had that happen on a set of 4wheeler struts.
Bearings and seals run me $80 guess another $100 or so wont hurt if it gets fixed right.
Any other ideas:chug:
2 weekends later and back on the road.No more rumbling sound.It is amazing what replacing shot wheel bearings and spindle bearings will do.:chug:
    Best for votes
    on specific items
