Tranny support plate??
tireman74
Celina, Texas
1982 CJ5
4.2L i6 258
T-176
Dana 300
AMC 20 rear and Dana 30 front
I'm not exactly sure what you call it but I would like to take it off so I can isolate a leak on my tc. What is the procedure to take it off? Frame bolts first or Transmission support bolts first? Or does it matter?
I'm not exactly sure what you call it but I would like to take it off so I can isolate a leak on my tc. What is the procedure to take it off? Frame bolts first or trans support bolts first? Or does it matter?
Skid plate/ crossmember
Remove the 2 mounting bolts in the center of the belly pan and the stud nut off to the side of these.
Place floor jack under the Transmission close to the belly pans front edge.
Lift until the Transmission mount just comes off the pan.
Then and only then remove the 6 pan to frame bolts.
The pan will come down with the drivetrain still on the jack.
Place a jackstand under the t case or Transmission before you get under there...safety first
