Trans skid plate dropped
godsey
tn
1979 cj 258 , amc 20,dana 30, t-150. original
When i took the bolts out of the skid plate ,the whole driveline fell down.this cant be normal is it? I was wanting to clean my Transmission and tf case any help apprciate:confused:
Yep thats normal.
The skid plate also acts as a cross member holding up the TCase and tranny.
i need one of these crossmembers. where can i find one. all the junkyards have crushed the jeeps around here
that must have been a thrill!:eek:
Put a jack under the bell housing to keep the tail end from dropping. Did you tear the motor mounts??
good looking fab job. I will admit to it being a cross member but not a skid plate.:D
what problem do you have with the stock skid plate??
The only problem I have with it is it fills up with mud and junk and is a PITA to clean out. I don't see you having this kind of problem in your hood.:cool:
The problem I had with the skid plate was it was cracking and about to break. The PO cut it (I guess to install the T-18 ). Now that is was smaller it started to crack bad.
No it is not a skid plate. With 36 inch tires on a CJ5 I never have a problem with scraping my belly. If I ever get around to stretching the wheelbase (pipe dream) I will add plates to the cross-member.
ohhh, i like that crossmember. do you have any dimentions, or plans?
Send me a PM if you still need one.
Trans 81 CJ8
