Transfer case lowering
BajaEdition
Resident 'Old' Jeep Shaman
- Featured
- 2
- Media
- 136
- Resources
- 2
- Riverside Ca
- 67 cj5,225 Dauntless, D30,chrome molies, detroit, D44, full floating detroit, custom steering, disc all the way around,2 inch lift on 31s, armored up
70 cj6 4 inch lift
the T-98 is almost 3 inches longer than the T-90 , if you did not get new driveshafts, I imagine you are having trouble.Hi Baja;
Sometime ago I swapped a T-98 to my 1962 CJ5 with DANA 18 transfer.( I keep the stock T-90 with the stock DANA 18 though) and as shown in "figure 2" I adjusted "0" degree.But while driving on highway every time the vehicle sprang downward a disturbing sound occured.It was something like when the fan touches the radiator shroud.( It wasn't the case though)Then I put degree vedges to achieve some degrees more than "0"
That sound was to some extend reduced ,but when the vehicle is loaded and while crusing on highway it occurs (slighter now) when the weight presses the springs downward.
I want to increase the degree of the vedges a bit more.If it still keeps I want to shift back to T-90
Any suggestion here will be greatly appreciated.
I really need more info on the swap and pictures. If you are serious about finding the problem I will tell you what to take pics of
, and then one of the rear drive shaft angle that I hope you guys can see. It may not be the best solution, but for a guy trying to save a buck and make his CJ a little safer to drive, this home made drop kit cost me all of about 5 bucks to make, and that includes paying the hardware store like .12 cents per cut x 10...
