transfer case noise...
PecosCJ7
Santa fe
1986 CJ7
5 speed
Dana 300
44 Axles rear, 30 up front
i have 1986 CJ7 with AMC 258 i6 / 4.2l , T-5 and Dana 300 . heres the problem i been hearing. when coming to a rolling stop and tranny shifted to neutral. im hearing a ticking/clicking sound from Transfer Case area. can almost feel it through shifter. noise stops when transfer case is shifted from 2hi to neutral.
what could be causing this?
thanks
Transfer Case maybe, u-joints would be a good candidate and cheep to repair, differentials and/or front axle u-joints. You just have to isolate them one at a time.:cool:
is there a way to test these joints? is it safe to disconnect front and rear drivelines from Transfer Case and run engine to test if noise still occurs
can we assume the hubs are locked when all this is happening??:cool:
