Transfer case swap
Haas
Bought a 78 CJ7 with a QuadraTrac Transfer Case . Did not know anything about the Transfer Case until after the purchase, my fault. Decided to go through the power train this winter, when we pulled the drain plug on the case a chunk of metal came out. We tore the Transfer Case apart and found the broken pieces, as you probably know we can't get the parts that we need and probably don't want them anyways.
I was thinking about the Dana 300 . I know I will have to swap the rear end to a center pumpkin style, but can I use the front axle and install locking hubs? It has AMC20 's front and rear. I also plan to upgrade the axle to the one piece design. I will need an adapter to go from the auto 400 Transmission to the Dana 300 and drive shafts. Am I missing any major components? Does anyone have a better suggestion? I know I could use the Dana 18, if I could find one, but I think now is the time to change.
Just looking for thoughts or suggestions. This is the first Jeep project.
Thanks in advance.
Thanks in advance.
