Transmission cooler
jbaker4341
I have a 700r4 tranny that is getting a little hot. It’s running around 200-210 with the original cooler which is mounted in front of the radiator. I’m looking at buying a B&M Hi-Tek SuperCooler with Fan 70297 to replace the stock cooler. Do you think that would solve the problem? Second option, replace the stock Transmission cooler in front of the radiator and then put the new transmission cooler with fan mounted elsewhere on the return line. Which way would you go and why? Thanks for any advice!!
81 Jeep CJ7 with V8 350, 700r4 tranny, Dana 300 Transfer Case , Dana 44 with 4.56 gear ratio
