Transmission or clutch problem
COCJ5
- Crawford, CO
- 1983 CJ-5, I6 258, T176, Dana 300, 3.54 AMC 20 and Dana 30, purchased 4/12/11 with 79000 miles on it.
I just bought an 83 CJ5 with 80,000 miles. It has the AMC 258 i6 / 4.2l I6 engine and a T-176 Transmission . When starting out cold everything works fine. After things are warmed up I cannot get the transmission into reverse without the gears grinding. All the forward gears shift with no problem cold or warm. Could this just be a linkage adjustment problem or something more serious.
Rod
Rod
if you have it gets more fun from here as it has internal shifter rail set up
