Transmission overhaul
BBCJ5
Texas
1980 CJ5; AMC 304; dana 30 Transfer case; T176 Transmission; edelbrock carb
I am about try and tackle overhauling my T-176 Transmission . I have the top off and all the gears look to be in good shape. I have the master overhaul kit from 4wd for all the small parts and bearings. Does anyone have any pointers for doing this?
Tear it apart and put it together within a few days of each other. ;)
Do you have a Transmission bearing puller? They make the job a whole lot easier.
I've never torn down a T-176 , but have done a few T-18 's, not sure how similar the guts are. Take pictures of the everything assembled, so if you have a question on how things go back together you can reference your pictures. :chug:
Print out one of those exploded view pics of the T-176 also. Lay everything out in order on a large enough and clean work area.
