Trans Transmission rebuild
Jadonal
Milton
1984 Jeep CJ7 Renegade
Does anyone in the Florida Panhandle, or even lower Alabama know of a trustworthy spot to have the T6 Transmission rebuilt? I’m in the Pensacola area.
So, are you referring to a Jeep Transmission ? Never herd of a T6 tranny. Borg-Warner makes a T-5 , 5 speed, Tremec makes several "T" series. If it just needs rebuilding Novak sells kits and parts to do DIY. it's not that hard to do. I just did my T177 and Dana 300 .
Sorry, and thanks for the response. It's a T-176 with a 4-speed. Adding on, the Transfer Case is a Dana 300 , which is a little difficult to shift into 4WD . I saw a clip on YouTube saying it's known to be a little difficult to shift into 4WD, and that a longer stick gear shift lever helps alleviate that. Any thoughts or opinions? As far as rebuilding goes, I've never rebuilt a Transmission , which is why I'm looking for a good recommendation.
Gotta start somewhere ;). I havent looked , but I bet theres a couple youtube videos of your exact Transmission to help you along. Take pictures of everything along the way for reference before and while dissaembling. I found a twin stick alleviated my Transfer Case shifting problems . (Link)-> JB Custom Fabrication LLC -<
While I don't have that same brand of twin stick, the setup is great for shifting the Dana 300 .
