Transmission/Transfer case mount
Jetsetr
Ok Braintrust...here’s today’s issue!
Noticed excessive vibration/movement in Transmission under load. Was hoping to find a broken engine/transmission mounts...
Instead found a trans to mounting plate issue...
Mount was loose, but it DOES NOT line up properly with the rear transmission-Transfer Case skid plate mount...
Previous owner was only using 1 bolt in the mount. Wondering if it’s the wrong transmission skid plate mount....
Unless I redrill the mounting holes in the skid plate there’s no way it’s going to work...(that is an option)...maybe I’m missing something obvious (and the skid plate does only go in one way, I checked!!).
Driveline seems to be lined up properly (would have to be several inches off to line up with the current skid plate mount).
P.O. really had no idea what he was doing on this, and obviously wasn’t a very good mechanic...
Ideas, suggestions, pictures??
Thanks in advance...
Dave
Dave
