U-Joint Style Steering Coupler
hagar
Old Time Jeeper
- Riverside CA
- 47 CJ2A
225V6
SM420
D18 w/Warn overdrive
D30 5:38 Power Lok
D44 5:38 Flanged Detroit Locker
So nice being able to change lanes on a highway around a curve and not feel like you are making a suicide attempt.
A scrambler and I formed a convoy this morning. I got a smile on my face as I watched him try to stay straight with the play in his steering.
With the notorious loose steering, I've always thought of CJs as being the first self-driving vehicles. It's the input of the destination information that is difficult.
Mine is a cheaper Omix-Ada Shaft. It installed easily once I had the steering column pulled back. I do have a tilting steering column. I believe it is OEM for mine since it's a Laredo version?
Not familiar with the '76 year or what steering column you're putting in and what the shaft type is. If it's GM, is there it's a good chance it's the same? The 1" DD is just the intermediary shaft that the U-joints connect to on mine. My column had a splined output shaft and was not 1"DD.
I'd say to count the splines and make sure they match up but unfortunately that gets confusing because of how the manufacturer/product description describes the count. The saginaw box input shaft counts only the splines used minus the flat tab part. The U-joint and drive-shaft manufacturers count the splines all the way around including where they normally would be for the flat tab part. I just had to trust the website I purchased from that it was the right product for my application and that the diameters were correct.
Sorry I can't be anymore help.
