Updaged gear ratio calculator with a speedo gear calculator
derf
Cedar Rapids, IA
1984 CJ7 - 5.3/4L60E/Atlas4spd/D44/9" - In Progress
1984 GW - 360/TF727/NP229/D44/M23 - NP242 swap in progress
1986 J10 - 360/TF727/NP208/D44/D60 - 700R4 upgrade in the works
I was messing around figuring out what speedometer gear I needed in my truck when I do the swap and decided to build a calculator for it. While I was doing that, I updated my main gear ratio calculator to match the rest of my website, along with cleaning up a few things behind the scenes.
Here's the new speedometer gear calculator. It's not finished yet. I don't have much source data to put in the drop down menus. But the arithmetic works. I'm going to be adding a form to calculate the internal shaft gear at some point.
http://www.grimmjeeper.com/speedo_gear.html
As always, the main gear ratio calculator is here:
http://www.grimmjeeper.com/gears.html
Thanks for all the work :notworthy:
Great job!! And where the HECK have you been! Not here, we know that! LOL
I've been busy. I've been working on doing some upgrades to the truck. Now that I'm in Iowa the chances of using a really built CJ are slim but a mildly built pickup will be more useful. So I'm going to get the truck built up a little and then start working on the CJ again next spring.
So your doing OK? Thats good to hear!
