Vac Advance unit part #?
RatDog8o8
- Iowa
- 1978 CJ-7 - 258 I6, T-18A, Dana 20, stock axles. 1992 Ford Ranger 4x4, 1995 Ford Crown Victoria Police Interceptor
I waded through the first 11 pages in this section, and then did a search for "vacuum advance".....either I missed something, or it's not there.
I have the stock Motorcraft ignition setup in my '78 CJ7 , which is fine for what I use the ride for. The only issue right now that I'm having is finding a replacement vacuum advance unit (bad diaphragm - no workee).
There's no part number on the one I have, just "Motorcraft" cast into the housing. The distributor has the following part # - D8FE-12130-AA. I can get another distributor, but mine's fine. No slop, shaft is not worn.
Anyone have any ideas as to what part number the vac unit might be? I don't care who makes it, as long as it does it's job.
Thanks!
Thanks!
