Build Thread Vader , A multi year Cj7
Woohoo!!! Glad you got it figured out and got it running!!!
Glad you got it running- for the record you’re not the first guy to set timing 180 out
Running is a good thing !
Definitely is. Inspected will be even better. That should happen in 2 weeks. Then maybe we can actually get to the fun upgrade stuff. That being said my focus will be on the trailer build 1st and foremost. I was going to take a vacation day and blast it next Friday but it looks like rain. May have to put it off until Monday.
I've been in the fun upgrade stuff for a while-non running.
Inspection revealed two soft spots on the frame that need repair. Taking in for an estimate today. 🙏🏼
$250 to get both areas repaired. I'll take it. One day I will learn to weld. One day. 😔
:) It's not just the welding but having the equipment. Glad to see you treading on. :chug:
Sad day. Went underneath the Jeep to clean up two more areas on the frame. Found two more spots with the old hammer and screwdriver check. That led to a complete hammer screwdriver check from front to rear. Thankfully no more soft spots.
Back to the shop tomorrow . Fixed before the weekend. Disappointed a bit but glad I went over it thoroughly now. Hurts a little more when I keep looking at the clean frame from the '80 in the garage. Just can't go the frame swap journey now.
On the good news side sold the tires off the '80 and have a deal set for the above mentioned frame. Upgrades coming very soon. ☺️
$20.00
  10.0%
