Venturi
Venturi
Cduke88
Poth, tx
1984 cj7
Hello. Does anyone know where I can just get the gaskets for the venturi instead of buying a whole kit?
What carburetor? What year?
On an administrative note, fill out your profile, not only was it something you agreed to when you created your account, it will help other members answer your questions.
Cduke88,
To get just a single gasket, you will have to find a carb rebuilder in your area, or someone that has some thin gasket material and cut one out. If not you can take a cardboard container, ice cream, Pepsi or something thin. Spray it with a silicone spray, and let dry, then install.
It is best to get the right part.
Hope this helps.
Just trying to fix the world one Jeep at a time.
Thank you. I have some gasket material but thought I could maybe find those somewhere. I might just buy the whole kit. I am sure I will need it sooner or later.
Cduke88,
I have a lot of Holley gaskets, but no Carter - always used everything.
We used to have a good carb man here that had everything, but he retired.
+1 on swapping, the kit for your carter is available at autozone and cheap at that, but its not going to do a huge amount of good for you. if its really hard to start then go for it, kit the whole carb tho, not just the base gasket. i will say tho, once you do this the carter will start to let you know why nobody uses it. get a mc2100 and thank yourself later.
