VIN location
VIN location
007
Crazy Sr. Respected Jeeper
Reno, NV
1977 CJ-7 Renegade (Daisy Jane), Levis trim, 304, TH400, BW1339 (MM), D30/Auburn Max, AMC20/Detroit/G2's, 4.88's, 33" BFG MT KM2's, Edelbrock Performer intake, Holley Sniper 4bbl EFI, MSD6, MSD ProBillet distributor, OME shocks, 4" ProComp lift.
Where all is the VIN located on a 77 CJ7 ? Can I keep my VIN if I do a YJ tub swap?
Windshield bracket, same bolts as wiper motor. Primary VIN.
Plate riveted to tub, engine compartment firewall. Under column or under bulkhead wiring connector.
Top of frame hump, above rear axle, passenger side. Forward part of hump.
Secondary location, load rating sticker with VIN, driver side interior left, right above jeep imprint. equivalent to "door sticker" on cars.
Driving a rust-belt jeep, I only have the windshield bracket one remaining. If you are missing yours, and don't have the others you may need to apply for a State issue VIN.
Carb computers had them as well, IIRC. Not sure if this applies to a 78.
Thank you! I'm sure I have all of them, but I want to keep the VIN when I change tubs so I wanted to know how to handle that. Sounds easy enough.
