Weber 32/36 on a 151 engine
adjective
Denver, CO
83 CJ-7 GM 151 Weber 32/36 AMC20
I just installed a Weber 32/36 on an 83 CJ7 's GM 151 engine. I am curious if anyone has photos of how the throttle linkage is supposed to be attached. I just sort of stuck the ball socket end of the throttle cable onto a part of the carburetor that seemed reasonable and then added a spring or two to make sure it would pull back when released. The way I have it now works, but I'm certain it isn't the "right way" to do it (that would be a miracle).
I bet that carb woke that motor right up!!!! is the linkage front to back or side to side? do you have any pic's of ur set up?
