Were to get Fuel Gage 78 CJ7
I am looking for a fuel gage for a 78 cj7. the gage is mounted in to the speedometer. Is there a site that has these or do I need to go junkyard diving to find one?
Thanks,
Jeff
Man that was quick, I had heard about that site but had not checked it out yet. Thanks alot for the info. 1 question,,will this simply come out by removing a couple of nuts from the back or do I have to remove the entire spedometer to replace the gage??
And if you use our site link to them it helps support the site...
I am looking for a fuel gauge for a 78 cj7. the gauge is mounted in to the speedometer. Is there a site that has these or do I need to go junkyard diving to find one?
Thanks,
Jeff
excelant point, sending units go a lot more often than gauges.Are you sure its the gauge itself? Many Cjs have inoperable fuel gauges but usually the gauge itself isnt the problem.
Well, lets just say that I was under the dash and connecting wires when I got it to work and then a bare wire hit one of the terminals and a small stream of smoke came out of the gage. Not sure but I think that means toast is done. LOL
The secret with electrical devices is to keep the smoke on the inside. Once the smoke escapes, bad things usually happen.
Never had one of those how do they workwarranty.![]()
most of the time,Never had one of those how do they work
LMAOI just put a polly tank in my CJ5.
This one seems to go empty all the time also. Have to keep filling it up all the time.~~~
I believe all CJ's have the same problem! Must be a design flaw! We use essential cookies to make this site work, and optional cookies to enhance your experience.
