Replaced the worn out flywheel gear ring on my '78 CJ5 AMC 304 . Only took 8 hours, 4 hours to get the flywheel ring back on the fly wheel, 4 to get the Transmission in and out... BUT IT'S DONE!
Prob. wrong spot to post this, but cool thread regardless. Got the new/used 84 CJ7 home. Has the AMC 258 i6 / 4.2l . Had a sp. plug wire arcing. So go to get new wires and other tune up parts.. Every parts place (Napa, Kragen etc.) I go to have the same length wires, but different brand names. None work! My dist. cap is next to the CENTER of the valve cover, so I need two 16" wires to reach the the plugs on each furthest end of the motor. All these plug wire kits so far have only one 16" wire and all the others are shorter. So no matter how I mix and match them, I come up with one wire that wont reach. Anyone else here ran into this problem? Think I just need to find another straight six app. with longer wires. Don't want to do the speed shop thing where you cut and fit your wires. too darn expensive. Thanks!!
Jeff
made a valiant but futile attempt to finish the dash wiring and put the dash and wheel back on. The new mechanical oil pressure gauge has a bit of a conflict with the defrost duct. It is a thermo plastic so heating it with a heat gun makes it pliable enough to get most of it out of the way but still had to trim the gauge mounting hard ware a bit. everything went well until old butter fingers dropped the gauge on the shop floor, It did not bounce and now it seems to think I have 10 PSI oil pressure all the time.
:dung:.
There goes $50 down the drain.
Prob. wrong spot to post this, but cool thread regardless. Got the new/used 84 CJ7 home. Has the 258. Had a sp. plug wire arcing. So go to get new wires and other tune up parts.. Every parts place (Napa, Kragen etc.) I go to have the same length wires, but different brand names. None work! My dist. cap is next to the CENTER of the valve cover, so I need two 16" wires to reach the the plugs on each furthest end of the motor. All these plug wire kits so far have only one 16" wire and all the others are shorter. So no matter how I mix and match them, I come up with one wire that wont reach. Anyone else here ran into this problem? Think I just need to find another straight six app. with longer wires. Don't want to do the speed shop thing where you cut and fit your wires. too darn expensive. Thanks!!
Jeff
Here you go. Magnecor Race Wires
Call Magnecor, and ask for Steve. they offer anywhere from stock to race wires. They fit perfectly, and they can custom make you a set, he made mine and shipped in one day. Unless you physically damage a wire, they should last just about for ever..Also, If you do damage a wire, they'll make you a new one and ship it right out.
I've got a T-18 6:32 first gear and a Scout TC146 Dana 300 with JB twin sticks. I added 4" to the (rear axle) shifter so now i can grab 2WD low real quick.
Installed home made Hi-Lift Jack mount on the rear of my roll-bar that works great. Will post pics as soon as I can. Getting ready for some wheeling first thing in the morning with our Meetup group Colorado Jeep People:grinjeep:
Drove it all over holy hell today, and ordered a new interior for the poor thing
