The only thing I’ve found with Rock Auto is it takes a long time to get what you order. At least it has for me. But if you don’t need it fixed tomorrow, it’s all good!
Weird, my orders are always two days. Is it an account setting?
Could be something as simple as warehouse location or their inventory. Last thing I ordered from them was master cylinder, front calipers and rotors. I wouldn’t think those would be hard to find items for them, but who knows.
I've gotten it next day often. Usually a day or so to arrive. But for the massive cost savings and amount of items they have its well worth it
You must login or register to view hidden content on this page.
Got about an hour’s work cutting sheet metal this morning before I was called back to go look for a Christmas tree.
Hopefully I can get back there later today. I need to fit a piece i’d just cut and ground to shape when the phone rang. That’s the back of a rocker panel and the stamped quarter will fit over it.
I need to get some regular work done too. Trash pickup is Monday morning. Need to fill the dumpster.
Built two subframe pcs to connect the 4 link and build a new skid plate off of for the 7 crawler
That be some mighty fine work.. is that a little Miller plasma I be spying on the bottom left? Looks just like mine matey!
It’s an old maxstar 200, similar to the modern miller dynasty but without pulse. Welds great though.
Umm... I'm talking about the little blue box that says "Miller" on the side..
Yep that’s it. miller maxstar 200. I don’t think they make that model anymore. The new maxstars are smaller.
Not a lot of functions but it does weld very nice
The simpler the better. I learned on a long stick that would bite your butt when you touched the wrong thing...
Bad pic, but upgraded the cap+adapter, rotor, and plug wires also getting the valve cover stripped down for replacement (finding grommets and such) This jeep’s been P.O.ed its a puzzle IMG_2292.webp
So my coolant saga continues. Thought I finally fixed the hose leaks, but after driving it yesterday, I opened the hood to find an antifreeze bomb had exploded. Coolant had sprayed everywhere, but there was no visible leaks. I think one of the hoses going to the water pump was dripping on the clutch fan. I tightened everything with a socket wrench, added more hose clamps, and took her for a drive today with no leaks. Fingers crossed this does the job.
Faded and dented, but still my favorite keychain.
Almost done with the new temp and oil gauge. My Sunpro gauges were failing, so I jumped on a black friday deal for a set of Summit Racing gauges. Only issue is they're too big by 5/8th of an inch. Spent the last four hours expanding the 2 inch hole with a dremel bit. It was hell! Had to wear a mask because the stuff was getting in my lungs. Besides the battle scares on the dash, I'm really happy with how its looks. Just have to hook up the copper line and temp probe tomorrow. Fingers crossed. 👍
Swapped my road trip BFG KM3 33s to save the tread and re installed my BFG KM2 31s. Good reason to have two sets of wheels. IMG_1155.webp
    Best for votes
    on specific items
