- Solutions
- 4
- Westfield, Wisconsin
- 1950 CJ-3A (Stock)
1/4 ton Military Trailer (Stock)
2004 Grand Cherokee (set up for expeditions)
As long as a good time was had by all.More trails in Moab.
Jeep did fine, until the 4th day when the front passenger main leaf decided to go flaccid. I flogged em pretty good for the last 4 years.
Time for a pair of new front springs.
View attachment 107061View attachment 107062
Sadly no, I am fairly sure it is a clamp, but I have been on night shift rather brain dead by morning, this is a hot leak or by now my radiator would be empty. My worst-case scenario means running a tap to cure a possible pulled thread. If nothing else the jeep gives me things to ponder lol such as fire, and a 5 lb hammer to punish it. Neither will happen. The joys of old jeeps!Coolant Leak......
1) You may have had a "Air Pocket" or "Air Bubble" in the system and it purged itself.
2) The system found it's level and it was coming out of the overflow tube into the frame somewhere. Now it has dried up.
3) Cold Leaks, can work both ways. After the engine cools down, it creates a Vacuum inside the system and stops the miniscule leak.
OR
after the engine cooled down, you Now Retighten Every Hose clamp as they have "Found Home" and are a little loose now.
Good Luck
It will be something simple.Sadly no, I am fairly sure it is a clamp, but I have been on night shift rather brain dead by morning, this is a hot leak or by now my radiator would be empty. My worst-case scenario means running a tap to cure a possible pulled thread. If nothing else the jeep gives me things to ponder lol such as fire, and a 5 lb hammer to punish it. Neither will happen. The joys of old jeeps!
There Ya Go !!Tried to make it leak yesterday, dry as a popcorn fart! I have no idea why and if it stays dry, I don't have to care why!
