3 days complete with no problems is not to bad. :chug:
After much time and energy to fix my coolant leak and much static run time I thought it was cured. No, the green juice escaped once again. So, I parked it a few days. Now for some unknown reason no drips! Perhaps the threat of pulling the AMC 258 i6 / 4.2l and replacing with a 302 ford V-8 had something to with this.
Coolant Leak......
1) You may have had a "Air Pocket" or "Air Bubble" in the system and it purged itself.
2) The system found it's level and it was coming out of the overflow tube into the frame somewhere. Now it has dried up.
3) Cold Leaks, can work both ways. After the engine cools down, it creates a Vacuum inside the system and stops the miniscule leak.
OR
after the engine cooled down, you Now Retighten Every Hose clamp as they have "Found Home" and are a little loose now.
Good Luck
WOW !!
Those are Beautiful.
Great Idea for additional storage and What A Classic Custom Touch!!
Yeah those are really cool looking. My seats are a little large so I’m not sure my doors would close though.
Coolant Leak......
OR
Good Luck
Sadly no, I am fairly sure it is a clamp, but I have been on night shift rather brain dead by morning, this is a hot leak or by now my radiator would be empty. My worst-case scenario means running a tap to cure a possible pulled thread. If nothing else the jeep gives me things to ponder lol such as fire, and a 5 lb hammer to punish it. Neither will happen. The joys of old jeeps!
