What fluids to run?
80W-90 gear oil. Same for the axles.
Get the gal bottle of Sta-lube and the hand pump.
On level ground-Fill till the oil runs out the filler, and then cap it off.
If you have a LSD rear diff. You need the 'friction modifier' for the Limited slip.
Set the bottle of oil in the sun for a couple of hours before you use it-Your shoulder will thank you for that. :D
If you have a LSD rear diff. You need the 'friction modifier' for the limited slip.
No LSD here sadly.. Open diff's and 2.73 gears. Been thinking about true trac's maybe for the future, but right now I just need to get her back to road/ trail worthy.
Get some Moser one piece axles and ditch those 2:73 gears. TT is a great LSD.
I'm a valvoline runner myself. Seems to be good stuff
